TwinTurbo.NET: Nissan 300ZX forum - Re: 2560 turbo install, turbo outlet piping trouble
Subject Re: 2560 turbo install, turbo outlet piping trouble
Posted by txq45 on March 03, 2011 at 10:10 PM
  This message has been viewed 248 times.
In Reply To 2560 turbo install, turbo outlet piping trouble posted by needa300zx on March 03, 2011 at 07:04 PM
Message Unless you have a KIT... JW or Z1 there would have to be adjustments because of clocking of the char, oil return clearance on DS, etc
Didn't mention which Kit or if a kit or using the OEM garrett turbo,, which would make a difference
I suspect your not using a Turbo kit ..in which the three bolt adapters for the outlets are at a different clock position. This turns the outlet pipe making it closer to the plenum and a little longer
Nistune Dealer
Parts www.aaa-hiperformanceauto.com
ECU socketing ECU eprom upgrade
